Roough Idle is Back... Part II.
Old Jul 30, 2004 | 04:49 PM
Ryan's LT1's Avatar
So I thought I fixed it with some Fuel Injector cleaner and cleaning/replacing the positive battery terminal... Well, now my slightly rough idle is back, this time with a VERY small hint of a hesitation. It revs nicely, all the way up to 6k and back with no problems. I am getting no SES lights. All guages look good...
I'm thinking it's the IAC, but I have no real reason to think that. It's the only thing I can think of that has something to do with idle air. Because when I am driving the car, it shifts nicely, drives perfect until I hit a red light, then it starts to stumble a bit. Now, I have already had my Opti fail on me before, and trust me, its nothing like how that felt at all. I would even go so far as to say that I am 99% sure that the opti isn't causing the problems.
So what should I check? Plugs? Wires? What are some sensors I should check, and how do I clean them/test them? I could really use your help here guys, it's been bugging me for a couple weeks now.
Old Jul 30, 2004 | 07:44 PM
n2ceptor's Avatar
Re: Roough Idle is Back... Part II.
MAP sensor???? IAC has carbon build up????
Old Jul 30, 2004 | 08:01 PM
turbo_Z's Avatar
Taylor wires are junk IMO.. Id search there for the problem first. Tonight go outside and see if the wires are arching. Check at the plugs, coil and even within the middle of the wire. If yours are like mine were then they will be lighting up like the 4th of July.
Old Jul 30, 2004 | 10:43 PM
Ryan's LT1's Avatar
I will check my wires, but how do you check sensors? Where is the MAP sensor, and how do I get to the IAC? How do i test the MAP?
Old Jul 31, 2004 | 03:09 PM
Ryan's LT1's Avatar
TTT Going to the Track Wednesday and need to sort this out...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Noenav
Mar 1, 2019 07:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
