roller rockers?
Old Feb 20, 2013 | 03:15 PM
shaunmotyka's Avatar
roller rockers?
what roller rockers should i use with a cc306 cam? 1.5 or 1.6
Old Feb 20, 2013 | 03:22 PM
Re: roller rockers?
You would use the higher ratio to get more out of it. There is no reason not to, with a cam of that nature.
Old Feb 21, 2013 | 03:42 PM
Bersaglieri's Avatar
Re: roller rockers?
Are your springs set up to handle the extra lift? That'd be my first question.
Old Feb 21, 2013 | 04:56 PM
KW Baraka's Avatar
Re: roller rockers?
Even with 1.6 rockers.....lift would be in the .570" range, I believe. Not that much of an issue but deffinately too much for old, worn out stockers.
I would use the Comp Cams Ultra Pro-Magnums in a 1.6 ratio.
And as Bersaglieri alluded to....get some new/decent springs that can handle .600" of lift.
KW
Old Feb 24, 2013 | 09:04 PM
Re: roller rockers?
stock heads ok with that too??
Old Feb 24, 2013 | 09:31 PM
RamAir95TA's Avatar
Re: roller rockers?
The 306 is not the best cam choice for stock heads. There are much better choices.
Old Feb 25, 2013 | 09:49 AM
Re: roller rockers?
i plan on porting the stock heads also.would it fit better than?
if not what cam would be nice with stock heads?
Old Feb 25, 2013 | 10:46 AM
RamAir95TA's Avatar
Re: roller rockers?
The 306 is an oldie but a goodie but isn't my favorite. I would pick a more advanced custom grind ANY day of the week when used with ported heads. Typically the two big porters AI and LE will customize a cam for their heads.
If you're sticking with stock heads I'd go with the 226/234 from AI. There's a few guys putting down 350+ cam-only and one even touching 360+ with that grind.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
