roller rockers
Old Oct 25, 2006 | 07:39 AM
95zsean's Avatar
roller rockers
Can I install 1.6 rockers on a stock set of heads?(CC non self alining)I know I need guide plates.
Old Oct 25, 2006 | 08:17 AM
Javier97Z28's Avatar
Moderator
Yes. Springs need to be upgraded.
Old Oct 25, 2006 | 08:18 AM
zx1216's Avatar
yep, get the 7/16 studs while your at it
Old Oct 25, 2006 | 08:26 AM
95zsean's Avatar
Thanks guys!!! I didn't think it was as easy as just puting them on and adj.them>
Old Oct 25, 2006 | 08:51 AM
2000GTP's Avatar
Yep, its a pretty easy and straightforward bolt-on.
Old Oct 25, 2006 | 05:09 PM
95zsean's Avatar
So do you have to change the Springs? Or can I just bolt them on?
Old Oct 25, 2006 | 05:54 PM
seawolf06's Avatar
Yes, do a search. You at least need LT4 springs.
Old Oct 25, 2006 | 06:08 PM
95zsean's Avatar
I Searched and came up with very little except that some people say just bolt them on and others say you have to replace the valve springs and push rods.I'd like to here from people that did both!!
Old Oct 25, 2006 | 06:12 PM
luckyou03's Avatar
you need LT4 springs if you using the stock cam. and I would get hardend pushrods & guideplates if you get NSA roller rockers. If you get SA roller rockers stock pushrods and no guide plates.
Old Oct 27, 2006 | 08:44 PM
foxbat's Avatar
this may answer most of your questions:http://web.camaross.com/forums/showt...&highlight=1.6
Old Oct 27, 2006 | 09:48 PM
Stoopalini's Avatar
For 1.6 NSA rockers, you will need guideplates (GMPP or ISKY adjustable sre good choices), replacement springs (LT4 work, and so do many others) and I would recommend replacing your pushrods with stock length (7.20") hardened ones. Some will say the '95s came with hardened pushrods from the factory, but I would replace them anyway.
The 7/16" studs are also a cheap upgrade, especially since the hole in the head is already 7/16", and the stock studs step it down to 3/8"; so the 7/16" ones just screw right in. You have to take them out to install the guideplates anyway, so might as well replace them with something better ..... just make sure the RR you plan to get are for 7/16" studs.
Thomas.
Old Oct 28, 2006 | 12:08 AM
StephenDeli22's Avatar
I have a dumb question but what advantage is there to a 7/16th stud over the 3/8ths?
Old Oct 28, 2006 | 01:51 AM
johnny3986's Avatar
They are a little over twice as thick on the part that the rocker arm is attatched to. Thus, in theory, being more apt to take a beating an withstand greater pressures created by high-revving and higher lifts.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
