roller rockers????
Old Jan 7, 2004 | 08:07 PM
Hershball's Avatar
roller rockers????
Has anyone put these on there car and they could tell a differnce????
LT1 95 Z28.
Old Jan 7, 2004 | 09:28 PM
FacelessZ's Avatar
Some have seen from 10-15 rwhp with 1.6's....1.7's are an option if you sticl with the stock cam...
NSA rockers with guideplates help with valve float where there is greater chance with SA rockers...
Old Jan 7, 2004 | 09:41 PM
ibanez6rg's Avatar
Yea, get some. NSA are stronger, also.
Old Jan 8, 2004 | 12:29 AM
Hershball's Avatar
I've got a set of 1.6 ratio GMPP RR, Will these damage my heads, springs. I've got a stock cam.
Old Jan 8, 2004 | 12:34 AM
drewstealth's Avatar
no they won't damage your heads. You should get some better springs that will handle more lift though. The stock ones would be at there very limit with 1.6rr's. You should also put some new valve seals on there when your doing the job. If you do a search you will find tons of info on it.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
