Roller Rockers
Old Apr 22, 2003 | 08:19 PM
NowuZitnowudont's Avatar
Roller Rockers
How much of a difference in idle and power is there with a set of 1.6 roller rockers? Looking for a cheap easy sorta quick attitude adjustment. What are the lift changes with the stock cam? Thanks!
Old Apr 23, 2003 | 12:34 AM
T/A#4's Avatar
Lightbulb
HARD TO SAY? SOME PEOPLE SAY 5HP OTHERS 17 HP. BUT TO USE ANY 1.6 ROCKER ARM IN A LT1 YOU MUST ALSO CHANGE THE VALVES SPRINGS ! tHATS WHY I HAVE DONE THIS , YET.
Old Apr 23, 2003 | 12:36 AM
delbuort's Avatar
I'm not sure about the horsepower gain but I put in a set of LT4 springs and you might want to go with the LT4 knock sensor too.
Old Apr 23, 2003 | 04:24 AM
Mtrhds94Z's Avatar
LT4 knock module, not sensor...
Old Apr 23, 2003 | 01:36 PM
delbuort's Avatar
Agreed, module. I stand corrected.
Old Apr 23, 2003 | 03:31 PM
RicocheT's Avatar
Was thinking about the same stuff for my car. If I got the correct STOCK cam lift numbers they look to be @1/5 .450/.460 and with the 1/6 .480/.491
I'm not sure how correct this was as I havn't found the specs on the cam and done the calc myself. I found it on a website somewhere.. if you want it i might be able to find it in my thousand bookmarks.
Also LT4 KM part number is 16214681 (also found somewhere so if it's not right then don't yell at me )
This should add a decent amount of power I would think, but then again I don't have dyno numbers to back up my theory.
Also if enough of yall are interested in getting some 1.6 rockers maybe we could get a group purchase or something going. I don't need mine anytime soon, but will want them prolly within the next month.
Old Apr 23, 2003 | 03:44 PM
mineralwater's Avatar
I think I actually lost HP going to 1.6RRs.. even with the lash properly adjusted, they clack a lot. And even with my lt4km, its pulling timing..
Old Apr 23, 2003 | 11:51 PM
delbuort's Avatar
I could go for that group order thing on the 1.6's.
Old Apr 24, 2003 | 12:41 AM
smokindastangs's Avatar
if your 1.6 RR's are clacking; i am almost positive that you don't have the lash adjusted properly. I though the same thing once; however, i went and gave it a double check and 3 rr's were loose. If i were you i would make sure that nothing is loose.
Old Apr 24, 2003 | 01:11 AM
Sanger's Avatar
Just how loud were your rockers? Could u hear them clacking and clinking real loud from inside the car or with the hood closed?
Old Apr 24, 2003 | 01:27 AM
ba96ta's Avatar
Did you adjust the rockers while the engine was on?
After installing my 1.6rr's and lt4 springs I picked up almost 2mph in the 1/4. And my car pulls alot better on the toppend
Old Apr 24, 2003 | 01:09 PM
RicocheT's Avatar
Ideally you should gain more topend hp as ba96ta did. I would recheck the adjustments, def shouldn't loose any power.
Also yea I would be up for a group thing if we can get a good price.. if you think a lot of people would be interested then we can make a post on the group purchase page.. For right now i'm just looking for some SA 1.6 roller rockers for the 3/8ths stud.
Although if everyone else wants to get something else i'm up for options.. price always makes me choose differently of course..
let me know :-)
Old Apr 24, 2003 | 01:30 PM
will62085's Avatar
how bout a group purchase on the RR's and lt4 springs...cause were all gonna need them both...but either way, count me in
Old Apr 24, 2003 | 03:51 PM
RicocheT's Avatar
Like i said cool with me, I don't need the LT4 springs, as i got them from a member already, but will def need the RR's :-)
Old Apr 24, 2003 | 05:17 PM
JDMZ28's Avatar
Hey I'd be in on a GP also.
