Roller Rocker Question
Old Jun 25, 2009 | 10:23 AM
joshmullins8's Avatar
I rebuilt my LT1 with the LT4 Hot Cam Kit and used 1.6 roller rockers, will I have to get taller valve covers or will the stock work?
Old Jun 25, 2009 | 11:15 AM
chevyz4life's Avatar
you can use them but you have to cut some of the braces inside them
Old Jun 25, 2009 | 12:04 PM
NJ-LE's Avatar
joshmullins8:
Depends ... if you're using aftermarket, Crane Gold Narrow body, Self-aligning 1.6 rockers then they work under the stock covers with no mods ... if the rockers are the "standard" size rockers then as Chevyz4life writes, the cover interior braces needed to be worked on. I'm told the Chevy 1.6 rollers that come with the full "hotcam or LT4 kits" are actually made by Crane and are the narrow body type and work with no interference. Why not set the rocker covers in place (no bolts) and crank the engine on the starter only and see if the covers start moving around?
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
