roller rocker knock
Old Dec 24, 2005 | 12:07 AM
jmh96z28's Avatar
roller rocker knock
got wat i beleiv is a roller rocker problem.guy i bought car from said since it is a newly rebuilt motor they need 2 b adjusted.had other ppl listen 2 it and they say it the roller rockers 2.but my problem is wat do i tightn them down 2 lik wat spec.how do i find wat kind they r so i can find out.he doesnt no wat kind they r either...kinda weird but watevr.or is there kind of a universal spec i can torque them dwn 2.
Old Dec 24, 2005 | 01:03 AM
Birdman7389's Avatar
Re: roller rocker knock
Good luck trying to quiet them down, I adjusted mine (self-aligning) 5 times, then gave up and went back to regular rockers. I could not handle the racket.
In my case the 10HP was just not worth sounding like a 15 year old Toyota.
In the future, I'm gonna try the non-self aligning ones, with a set of LT4 vavlecovers.
Old Dec 24, 2005 | 06:42 AM
ABA383's Avatar
You need to find out what brand of lifters you have, too...The stock type lifter will require you to go 1/2 turn past zero lash on the rocker adjustment nut. But if you have Comp Rs its a different setting...My car has stock type lifters and with the cam I have it sounds like a sewing machine and thats normal...Its real hard to diagnose anything online without seeing the car...Have a competent mechanic have a listen and maybe you and him can adjust them...
--Alan
Nutty's96
Dec 21, 2015 06:25 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Mir Hussain
Outside of United States
Aug 8, 2015 07:00 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
