Anyone here have a cc305 on a 110 lsa?
Old Dec 19, 2005 | 08:31 PM
Kreinmc's Avatar
I think this cam would be able to make some decent power and allow me to keep my 1.7 rr's. I am also hoping that this cam will give me a lower power band and allow me to shift at 6200 or so and still make around 345rwhp. What do you guys think?
Old Dec 19, 2005 | 08:44 PM
Projectz28's Avatar
Moderator
Re: Anyone here have a cc305 on a 110 lsa?
You dont need to have that cam on a 110 to do that. There are several guys on this board including me who run the off the shelf cc305 and do exactly what you are looking for.
Old Dec 19, 2005 | 08:47 PM
Kreinmc's Avatar
I've already owned a 305 on a 114 and would like to make just a tad more power and be able to shift it lower. I don't think that a 110 lsa is really that radical on a 305 and it would probably perform fairly well.
Old Dec 20, 2005 | 08:04 PM
Kreinmc's Avatar
No one here has one?
Old Dec 20, 2005 | 10:11 PM
Z28barnett's Avatar
The CC305 is available from comp on 112 + 4 , or 114 + 4.
Perhaps the 112 would be a good middle ground and not eave a custom grind.
Z28
Old Dec 20, 2005 | 10:59 PM
BananaBelly's Avatar
I had mine ground on 112 and loved it..no cats, longtubes and cutout before the flowmaster sounded kickass too.
Old Dec 21, 2005 | 12:55 PM
Kreinmc's Avatar
My buddy had his 305 on a 112 lsa and it ran pretty good, but I would like my powerband to be lower and make more power than his did.
Old Dec 21, 2005 | 02:22 PM
RealQuick's Avatar
I was always under the impression that the more overlap, the higher the power band...so if you want to shift lower, get it ground on a 116lsa, not a 110lsa. Correct me if I am wrong.
Old Dec 21, 2005 | 02:33 PM
89385formula's Avatar
Yeah you are thinking backwards on that thought. However Theres is much more to the cam equation tham just the LSA, especially for shifting the powerband up or down.
Rather than trying to make up your own cam, why don't you talk to a professional and tell them what you are trying to do and get a recomendation.
Old Dec 21, 2005 | 05:07 PM
RE AND CHERYL's Avatar
Ditto! The 110LSA is going to force the power band up, not down. If you want more power. Get a bigger cam, but the power band will be shifted up and you will have less power on the low end. There is no way around that.
Unless you stroke it.
Old Dec 21, 2005 | 05:16 PM
Mindgame's Avatar
Tests within, comparing like cams with changes in lobe seperation only....
http://www.babcox.com/editorial/ar/eb90252.htm
RE AND CHERYL will want to read the article...... together.
-Mindgame
Old Dec 21, 2005 | 05:37 PM
To quote a portion of an older post by Mindgame.
.......If you want to talk generalities, the tighter LSA will make more avg tq and hp in the lower revs and may make for more fun on the street where as the wider lsa will pull harder from mid rpm to high and will hold on further past peak tq. This is all considering an identical engine... just the cam swapped. 2º one way or the other is not worth much IMO and there is some truth to what 96caprice is saying in terms of using lsa to run a larger camshaft. David Vizard has been saying the same thing for years and he's been around the block a few times. Pay attention to your dynamic compression and see how these changes effect it. Software can help.... trends are your friends. ...
Old Dec 21, 2005 | 08:34 PM
marshall93z's Avatar
BACKWARDS!!
Old Dec 21, 2005 | 08:49 PM
Kreinmc's Avatar
Thanks for the link mindgame. I think 110 lsa would be the way to go after reading what vizard had to say. The 305 on a 110lsa will still idle and drive much better than my 306 because the 305 has an overlap of 5 and the 306 has an overlap of 13. Vizard said that having too wide (114) of an lsa will most likely have more of a negative effect than too tight (110) of an lsa. Maybe an lsa of 110 is optimal for this cam.. who knows. I chose this cam because I know it performs well and I am limited to what I can do because of my 1.7 rr's. I will keep everyone updated with dyno numbers when I do this.
Old Dec 21, 2005 | 08:54 PM
Mindgame's Avatar
Thumbs up Re: Anyone here have a cc305 on a 110 lsa?
Good luck with it.
Glad you got something out of the article.
-Mindgame
