Rod knock, trading in...just replace bearings?
Old Jul 19, 2005 | 09:29 PM
Birdman7389's Avatar
Ok, this is on my 97 formula, 69K miles.
Long story made short- I believe have a bad rod bearing,not at idle, but at the "sweet spot" where you are not on the gas much but not coasting. some metal in oil/filter. Plenty of oil pressure. This just happened and has been driven for around 5 miles since the noise.
I had planned on trading this car in on a new Chevy Colorado/Canyon.
Can I just order up the rod bearings, lube and a pan gasket, replace them from the bottom, and send it away? Would the motor possibly be ok?
Just thinking out some options here....I have found a similar mile shortblock for $500 local....
Old Jul 19, 2005 | 09:37 PM
94 NO TOP Z's Avatar
Re: Rod knock, trading in...just replace bearings?
If indeed the rod is knocking it is probably way too far along and has damaged the crank and/or rod. You will probably need to regrind or replace the crank and/or resize the rod.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Hurin
Dec 13, 2014 07:38 PM
jayblev95
Dec 1, 2014 06:55 AM
