Rocker Stud Question
Old Feb 1, 2006 | 05:11 PM
Stoopalini's Avatar
I just received a set of ARP 134-7103 7/16 rocker studs for my Scorpion 1.7RR install. I set one of the Scorpion rockers onto a stud and noticed the rocker sits down on the stud so far, the bottom of the rocker hits the hex bolt of the stud.
Shouldn't the rocker tighten up against the stud before the bottom of the rocker makes contact with the stud?
Do I need different studs, or do I need to clearence the stud or rocker?
Thomas.
**** edit ****
Ok, I just realized my stupid mistake. With the stud and rocker not installed in the head, the rocker will seat all the way down. But once everything is in the head, the pushrod and spring will keep the rocker from dropping down all the way and making contact ...... does this sound right?
Old Feb 1, 2006 | 05:19 PM
RamAir95TA's Avatar
Re: Rocker Stud Question
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
alphaauto
Jan 23, 2015 07:42 AM
95chwagon
Jan 13, 2015 09:19 PM
