Rocker Q's
Old Jan 8, 2007 | 02:31 PM
Alex607's Avatar
Rocker Q's
Hi, I am choosing some roller rockers to put on my car, my cam is 1.5L, if I went with 1.6L on the rockers, would I still have clearance, or would it still be too much? and stud 3/8 correct?
Old Jan 8, 2007 | 03:32 PM
seawolf06's Avatar
If you're talking about valve cover clearance, nearly any aftermarket rocker will require modifying the valve covers, it's not hard though. That's the only clearance issue I know of. I would suggest upgrading the rocker studs to aftermarket as well. 7/16" is better as long as you get the rockers to match.
Old Jan 8, 2007 | 03:34 PM
speed_demon24's Avatar
I have some crane s/a 1.6 rockers for sale that clear the stock valve covers if you are interested.
Old Jan 8, 2007 | 04:15 PM
2000GTP's Avatar
Is your car otherwise stock? If you have a stock cam and the only mod you plan on doing is the rockers, then self-aligning 3/8 stud rocker arms should be more then adequate. Depending on what brand you go with, you may have to clearance your valve covers, it isn't a big deal and there are plenty of writeups on here that go through it.
Old Jan 8, 2007 | 05:57 PM
seawolf06's Avatar
What springs are you going to use?
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
