Rocker Q's
If you're talking about valve cover clearance, nearly any aftermarket rocker will require modifying the valve covers, it's not hard though. That's the only clearance issue I know of. I would suggest upgrading the rocker studs to aftermarket as well. 7/16" is better as long as you get the rockers to match.
Is your car otherwise stock? If you have a stock cam and the only mod you plan on doing is the rockers, then self-aligning 3/8 stud rocker arms should be more then adequate. Depending on what brand you go with, you may have to clearance your valve covers, it isn't a big deal and there are plenty of writeups on here that go through it.
