rocker loosened up
Old Jun 14, 2008 | 01:08 AM
ttop1986's Avatar
rocker loosened up
I just put in crane gold 1.6 rockers, and set the pre-load at 1/2 turn past 0 lash. I put the locking allen wrench set screw into the poly locks, but I didn't use any thread locker. One loosened up at the track. I'm going to have to check these all sometime, but would it be advisable to use thread locker? And if yes, then on the poly lock, or on the set screw. Thanks.
Old Jun 14, 2008 | 06:03 AM
The purpose of the set screw is to not have to use any thread locker. There must be some other reason it is loosening.
Old Jun 14, 2008 | 08:05 AM
Pontiac_97's Avatar
DONT use thread locker! Did you tighten them down pretty good while having a normal wrench on the nut so it doesnt loosen or tighten the rocker anymore?
Old Jun 14, 2008 | 09:12 AM
ttop1986's Avatar
I turned the set screw while holding the polylock with a wrench. I didn't turn it the polylock anymore after, because I heard it can break.
Old Jun 14, 2008 | 04:34 PM
ttop1986's Avatar
Ok.. My car is 45 minutes away from my house because I didn't want to drive it with the loose rocker. I'm planning on going to fix it and then drive it home. I have one question...
If I come across a broken poly lock, is it ok to throw on my stock 1.5 rocker on that one valve to drive it home?
Old Jun 14, 2008 | 04:59 PM
NJ-LE's Avatar
ttop1986:
"If I come across a broken poly lock, is it ok to throw on my stock 1.5 rocker on that one valve to drive it home?"
It wouldn't be a problem ... bring a spare pushrod too in case the original has been bowed.
good luck ...
Old Jun 14, 2008 | 06:16 PM
Pontiac_97's Avatar
it shouldnt be too hard to fix. only a few minutes and it should be driveable again
Old Jun 14, 2008 | 07:57 PM
ttop1986's Avatar
Well I made it home! It was easy to figure out which rocker it was. Very obvious just looking at the poly lock and seeing how deep the set screw was in it.
I'm going to have to order a new rocker from crane. I put a stocker on for the ride home.
Old Jun 14, 2008 | 11:52 PM
marshall93z's Avatar
I have NEVER had a rocker come loose. Set 'em once and forget 'em.
Just get 'em tight!
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
