Rocker help needed FAST!!!!!!!!
Old Feb 7, 2007 | 01:32 PM
  #16
LesPaulGoth's Avatar
Originally Posted by SS RRR
I'd be a little leary about buying those. A person I knew from another board bought something similar to those (NSA) and because the rocker body was so huge they bottomed out on the hex part of the studs, pulled two studs out of the heads, all the rockers were gouged where it made contact on the studs, bent the pushrods from the two studs that were pulled out and most of the other pushrods were eaten from being pushed into the guideplates. He didn't know a whole lot and had a shop install them who of course didn't know WTF they were doing.
If you are going to go with those make sure to check the rocker body to stud clearence.
I'm sure they will work fine, you just have to have the correct size pushrod, and lash the rockers properly. My guess is that when they installed the rockers, they just sinched them down without even taking into account valve lash, and they were too tight to begin with.
Old Feb 7, 2007 | 04:56 PM
  #17
SS RRR's Avatar
That would be your guess, but you would be wrong.
Old Feb 10, 2007 | 05:08 PM
  #18
9formula4's Avatar
They will work fine. I contacted crane and they said they state that so that people who do not know a lot about the motor building process will ask questions before buying them. I have new pushrods coming. I went with the 7808 comp cams pushrods.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
