Rocker arms wont stay tight
Old Aug 27, 2005 | 02:37 PM
$hawn's Avatar
I have the comp cams pro magnum rocker arm and when I turn the engine over the ones that I just adjusted come right off the valve and pushrod but the nut is tight. What could be wrong?
Old Aug 27, 2005 | 04:11 PM
Re: Rocker arms wont stay tight
Lifters collapsed or your not adjusting them correctly.
Old Aug 27, 2005 | 04:41 PM
Colin91Z's Avatar
$hawn, I have done this may times, if you want I could stop by and see if I can help you figure out what the problem is. You still have my cell # right?
Old Aug 27, 2005 | 06:34 PM
$hawn's Avatar
Hears the deal, I put new heads and thinner head gaskets, so at first I used stock lenght pushrods, there too long but I had them adjusted fine, then I put some shorter pushrods in and the car woudnt stay running. Figured out that the rockers arent staying tight after I adjust them, I turn the motor over and the ones I did are real loose. The lifters I cant push in with the pushrods by hand so they seem to be pumped up, I think.
Old Aug 27, 2005 | 06:40 PM
You should not change pushrod length unless you have determined that you need it to maintain proper geometry.
Old Aug 27, 2005 | 07:04 PM
$hawn's Avatar
Right, I used a pushrod lenght check, I didn't mean for it to sound as if I just put in some shorter ones laying around.
Old Aug 27, 2005 | 09:24 PM
Good. It's always helpful to have all the info.
Old Aug 28, 2005 | 07:43 AM
slopokrodrigez's Avatar
What's the part number of the rockers you used?
Old Aug 28, 2005 | 09:04 AM
$hawn's Avatar
The 1305, 1.6 7/16 non self aligning.
Old Aug 28, 2005 | 09:23 AM
30696bird's Avatar
I used the same ones. Did you get the guide plates? I had no issues with mine. You ought to have colin91Z come over and help you out.
Old Aug 28, 2005 | 06:18 PM
So do you have guide plates?
Old Aug 28, 2005 | 07:55 PM
$hawn's Avatar
Yes I have guide plates, once I pulled my head out of my butt, I got it, I think the problem was I didnt adjust some of them at tdc, and once I turned the motor over they were loose, but I got some help to watch the valves this morning and got it figured out.
Old Aug 29, 2005 | 02:19 PM
Not to beat a dead horse but you did get hardened pushrods to use with the guide plates didn't you?
Old Aug 29, 2005 | 10:54 PM
$hawn's Avatar
Yes sir.
Old Aug 30, 2005 | 06:42 AM
cehan's Avatar
I understand that the standard SBC guide plates aren't properly spaced for LT1's and will cause the roller rocker to ride offcenter on the valve stem. The ones to use are the GMPP p/n 14011051.
Chris
69z-28
Jan 29, 2016 10:46 PM
KamikaZ28
May 28, 2015 12:45 AM
Sauced
Apr 12, 2015 10:18 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
