Rocker Arms
Old May 20, 2007 | 12:58 AM
damastertechjj's Avatar
Rocker Arms
Can I put roller rockers in my 1993 Camaro Z28 stock and increase lift and with the increase lift, I am asumming more power with out changing heads, cam, and the bottom end. And if I increas lift, would there be sufficient room between the Piston and Valves? And if anyone has done this What kind of power gain can I expect with different rocker ratios?
Any parts suggestions would help from low cost to the best?
Last edited by damastertechjj; May 20, 2007 at 01:01 AM. Reason: not detailed enough
Old May 20, 2007 | 05:05 AM
2000GTP's Avatar
You can upgrade to 1.6 roller rockers without a problem and won't have any P-V issues. Definitely upgrade the valve springs though to at least the LT4 set which runs around 35-40 dollars. You may see gains of around 10hp.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
