rocker arm clearancing to stock valve covers
Old Dec 29, 2008 | 12:03 AM
Zigroid's Avatar
just wanted to throw some high resolution pictures up showing what I had to cut to clearance the stock valve covers for my comp pro mag rockers. I don't know if there is any difference in clearancing the valve covers for other rockers or not, I would imagine not much. anyways since I searched and only came across one tiny pic this should be nice for anyone looking for good pictures in the future.
(cz28 scales the pictures down some, originals are like 2000 pixels wide)
Old Dec 29, 2008 | 12:20 AM
PHINES LT1's Avatar
thanks i will be doing this later this afternoon. just because i can be a tard....the braces that you cut are on the outside half, as in closer to the header?
Old Dec 29, 2008 | 12:47 AM
speed_demon24's Avatar
You could have just bent the bottom part 90 degrees instead of cutting the bracing.
Old Dec 29, 2008 | 01:02 AM
marshall93z's Avatar
Some told me I had to cut it ALL out and that's what I did. Now I have leaky valve covers.
Old Dec 29, 2008 | 02:48 AM
Romero155's Avatar
^^ I have that same problem, i need hit the junkyard up and find another set to cut them like Zigroid did
Old Dec 29, 2008 | 07:31 AM
a4z28's Avatar
Try ebay you can get some for about 20.00.
Old Dec 29, 2008 | 08:30 AM
Zigroid's Avatar
the valve cover bolts arent directly in the center, the wider side had to be cut. I think it was the intake side.
I like cutting and grinding stuff though. you should see my grinding on my intake to fit the 58mm throttle body.
Old Dec 29, 2008 | 09:27 AM
PHINES LT1's Avatar
makes sense, thanks again. I like to "make" my own stuff as well, just made an A/C delete panel last night for half the price it would take to buy one.
Old Dec 29, 2008 | 09:51 AM
MeanGreen97Z's Avatar
I have 3 sets. PM me and I'll give them to you for the price of shipping.
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
