rocker arm
Old May 19, 2010 | 04:36 PM
camarolover97's Avatar
rocker arm
does anybody know what the torque specs are for the stock rocker arm bolt?
Thanks George
Old May 19, 2010 | 05:15 PM
joeSS97's Avatar
The torque for the studs is 60 foot pounds.
Old May 19, 2010 | 05:22 PM
yea i torque it down to 50ft lb from the shoebox website and when i was done the valve was compressed to hell lol didnt not right
Old May 19, 2010 | 07:34 PM
Stl94LT1's Avatar
You don't torque the rocker nuts. You need to set the preload.
Old May 19, 2010 | 08:19 PM
Torque value for the stud into the head is 50 lb. ft.
The nut on the rocker arm is not torqued. It is set to zero lash and then preload added.
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Old May 20, 2010 | 06:30 AM
yea i did that after i put everything back and it worked fine, even before i started to do that there was because there was a rattling noise and when i would drive off it turned into a clunking noise from the passenger valve cover.
would anyone know what it could be
Old May 20, 2010 | 11:53 AM
Slick-Z's Avatar
Could be that you did not tighten the rocker arms down tight enough. Did you make sure you went that 1/2 or 3/4 icnc turn after zero lash.
Old May 20, 2010 | 12:09 PM
craby's Avatar
did u run the motor with the rocker torqued to 50 ft lbs?
Old May 20, 2010 | 12:41 PM
Slick-Z's Avatar
When i did my valvetrain setup i had bought new heads with the rocker studs already installed. With the rocker arms i wound up doing the turn the pushrod back and forth while tightening down on the rocker arm until all play was removed and i could not turn the pushrod side to side anymore which was my zero lash and then did a 3/4 inch turn after that and i have had no problems since. And also if you do not get the rocker stud to the correct ft ibs then your valve clearances will not be correct and your rocker stud could come loose after a little vibration from operation.
Old May 24, 2010 | 02:47 PM
yes i did
Old May 24, 2010 | 02:48 PM
no didnt want to try that
Old May 24, 2010 | 02:51 PM
ok thank you for your help but the rattling noise came out of nowhere one day im driving then the next day it make a noise like a bolt is in my vale cover and when i drive it clunks
Old May 29, 2010 | 02:34 PM
craby's Avatar
have u reset the lifters? could it be one has come lose? run it with the valve cover off and see if you can locate the noise a little better.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
