rocker adjustment w/out timing cover removal
Old Mar 18, 2003 | 02:06 PM
Seanndogg's Avatar
I just took my heads off and now I am putting them back on and I really dont wanna take off the radiator and especially the timing cover! Can't you adjust the rockers while the car is running or something?
Old Mar 18, 2003 | 02:08 PM
jonaddis84's Avatar
Dont know what you mean, but you never have to take the timing cover off to adjust the rockers, theres a few ways to do it. The easiest is to put piston 1 at TDC and piston 6 and adjust, you will need a haynes manual to tell you exactly how to do it, but no you dont have to take it off.
Old Mar 18, 2003 | 02:23 PM
Seanndogg's Avatar
I could swear I had the timing cover off when I adjusted my rockers the first time. I thought you needed it for to get to the crank bolt... It has been a long time. Nevermind I guess.
Old Mar 18, 2003 | 03:28 PM
GREGG 97Z's Avatar
I used the method he mentioned recently when I had to readjust mine. I used this guide from Shoebox's site and it worked well.
Old Mar 18, 2003 | 03:48 PM
Dr.Mudge's Avatar
As long as you put your crank hub on properly there is no need to have the timing cover off. Look at the arrow on your dampner.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
