rocker adjustment
Old Nov 4, 2008 | 08:22 PM
Maverick_997's Avatar
rocker adjustment
alright so i got that famous "sewing machine" sound comin out the valve covers and today i decided to pull the valve covers. i did the running adjustment, but i noticed that about 5-6 of the ones on the passenger bank didnt start ticking till 1 full turn of the nut.. sooo if they were ticking at about that much of a turn should i turn them farther than that??
jeremy
Old Nov 4, 2008 | 08:44 PM
camarobird92's Avatar
Tighten them until they stop ticking, + 1/2 turn.
Old Nov 4, 2008 | 08:49 PM
Green96Z's Avatar
Ticking is to be expected with aftermarket rockers. If you set too much preload you will lose HP and possibly damage a lifter.
Old Nov 5, 2008 | 02:19 AM
MarcR94v6's Avatar
I had my stock rockers adjusted because some were loose (they didn't sound right), as the shop confirmed when they took a look. They are still loud like aftermarket rockers!
Old Nov 6, 2008 | 09:04 PM
following up on my rocker noise, i adjusted them 3 times now and still have a light tick(much better than before but still noticeable).. the last adjustment i did while running and tighten them a turn and a half.. changed oil and added soem "greased lighting" and still have a little tick.. any suggestions? lifters?
jeremy
Old Nov 6, 2008 | 09:06 PM
LaredoZ28's Avatar
I dont think it would b a lifter. Lifters are usually prettty loud when they have problems. Some rockers are just noisy after a while.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
Slayer
Aug 17, 2015 03:55 PM
realistyc
Jul 28, 2015 07:32 PM
JCSWS6
Jul 19, 2015 06:47 PM
