Rocker adjustment?
Old May 16, 2004 | 07:47 PM
polcat1p's Avatar
Rocker adjustment?
Ok, i adjusted the first set of rockers 2,5,7 intake, and 3,4,8 exhaust then turned the crank 360 degrees. Then i adjusted the rest. My ? is the i can spin the pushrods on the first set after i went 360. There not loose, but i can spin them. Is this normal? I did just what my manual said.
Thanks Chad
Old May 16, 2004 | 08:35 PM
ibanez6rg's Avatar
That's normal, the lifters bleed out after you set them.
Old May 16, 2004 | 08:51 PM
viperkiller's Avatar
what he said
Old May 16, 2004 | 09:05 PM
"White Knight"'s Avatar
i need to learn how to adjust rockers...........that's why i don't have a set yet.......not sure how to do it exactly.
Old May 16, 2004 | 09:37 PM
Read up. Also explained is the pushrod feeling loose after adjustment.
Old May 16, 2004 | 09:41 PM
Pasky's Avatar
Easiest way by far IMHO, do it with the engine running, that way you can hear them clicking.
Old May 17, 2004 | 04:44 PM
97s10ondubs's Avatar
if you adjust them with the engine running, you wont get oil all over the place?
Old May 17, 2004 | 05:05 PM
Xride's Avatar
that what I though too, but it does seem the easiest, i mean the writeup for that isnt even a paragraph
and the other one if like a page
Old May 17, 2004 | 07:32 PM
Pasky's Avatar
I had tiny drops go over the heads but other than that, no. Mine didn't really leak at all. No oil on the concrete what so ever.
Old May 17, 2004 | 07:39 PM
polcat1p's Avatar
I tried doing it with the motor running, but my car made a mess. I do have a high idle though. With my headers, i cant here the rockers. Who knows, maybe its my headers that are making the ticking noise, and not the rockers. If i know my rockers are done right, then that only leaves one other thing it could be
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
Slayer
Aug 17, 2015 03:55 PM
realistyc
Jul 28, 2015 07:32 PM
JCSWS6
Jul 19, 2015 06:47 PM
