Richmonds and noise?
Old Jan 22, 2004 | 04:38 PM
RMC's Avatar
RMC
I can get a rear with new richmond 3.42's and all new guts for very cheap, but it's got a little bit of a whine too it. Right now I have a rear end that needs new gears, seals, bearings, etc, etc which will cost more than the cost of this rear.
Question is, do richmonds naturally have a little bit of a whine or is this something that could get worse and louder and louder over a little time?
Ross
Old Jan 22, 2004 | 05:01 PM
TRIPLE G's Avatar
I have a eaton posi trac with richmond pro gears(3.73) in my car. Yes they will whine. Its not to bad though. I have had mine for about 16k miles and the noice levels have not gone up that i can tell.
Old Jan 22, 2004 | 05:04 PM
flyinZ's Avatar
I have a Richmond set of 3:73's, and they whine @40mph, and thats its...I think it was the fault of the install...not the gears themselves...They are one of the strongest gears from what I hear though...
Derrick Redd's Avatar
I have Richmond 3.55's in my LX and they have a little whine. I hear that it's common. So I'd say go for it.
Old Jan 22, 2004 | 05:17 PM
Cmr0z28's Avatar
A little bit of noise is normal. If you have to yell over the noise due to volume, then there's something wrong, but a little bit is normal. My strange's whine from about 40-44mph. From what I've seen, ALOT of gears whine in that range, so to the guy who posted before about his gears whining at 40mph, it's normal man.
The instruction papers that came with my gears even said a little whine is normal. Don't let it bother you unless like I said, it's loud and annoying.
Old Jan 22, 2004 | 05:26 PM
RMC's Avatar
RMC
Yeah, I have a different set of 3.73's in my car now and they were fine for a long time then all of a sudden they just got deafening loud, my pinion started leaking, and all these problems.
So I want to get this whole new rear and install it, then fix my current later with some 4.10's when I have time and more money to do it up.
Anyway thanks for the info.. I'll probably go ahead with this cuz a little noise is a big improvement from what I got now.
Old Jan 22, 2004 | 06:30 PM
Cmr0z28's Avatar
Yep go for it, ditch the rear you have now and save the money for a 12-bolt. I wouldn't put any more money into the 10-bolt.
Old Jan 22, 2004 | 07:09 PM
RMC's Avatar
RMC
Hey what's up.. you got a 12?
BTW got the cutout looks great, thanks.
Ross
Old Jan 22, 2004 | 07:31 PM
AsianSensation's Avatar
The whine is from the nickel content in the gears to make them stronger. More nickel = more whine = stronger, less whine= less nickel = weaker.
Old Jan 22, 2004 | 07:38 PM
442olds's Avatar
I have a set of Richmond 3.70's in my Vette which I set up myself. No whine whatsoever. Well lets put it this way, it would have to be really loud for me to hear it over the rumbling big block under the hood. My cutlass had 3.42 richmonds in it as well, no whine, but was professionally set up. Did have the tools I have now back then. I wish I still owned that cutlass.
Old Jan 22, 2004 | 07:52 PM
Cmr0z28's Avatar
Ross
Hey Ross. Nope, I got the stock 10-bolt with Strange 3.73s. I was just saying instead of spending the money on a new rear AND rebuilding the old one, just get the new one and keep the other money in case a 12-bolt is needed.
was nice doing business with you
-Matt
Old Jan 22, 2004 | 08:35 PM
97WRAITH's Avatar
I have had richmond gears in two of my cars and they were set up professionally and they both whined.It is normal as long as it is not excessive.
Rob.
Old Jan 22, 2004 | 09:13 PM
97SS0594's Avatar
richmond 4.10s they wine like a banchee but the quality is worth it just turn the radio up or open up the cut out
Old Jan 22, 2004 | 09:34 PM
Antz97ZNJ's Avatar
My richmonds whined like a baby, after I broke thos pos's from merely changing over to nittos I got a set of gm motives..night and day
Old Jan 23, 2004 | 07:02 AM
IDOXLR8's Avatar
That is the truth.
