Reverse Flow
Old Aug 18, 2003 | 11:29 AM
SantaCruz163's Avatar
Reverse Flow
I'm just wondering how the head design and block design are different than those of a regular SBC. What are the pros and cons of having reverse coolant flow?
Old Aug 18, 2003 | 12:47 PM
CamaroBoy96Z28's Avatar
Water passages are just a different design than standard Gen I SBCs. The only cons I can think of is you cant use 18* or 15* SBC heads without it getting very expensive converting to work with the LT1/4 Gen II block. Plus we need the special thermostat as well. On the up side we can run high compression on pump gas, upwards of 12:1. I'm not sure how high the compression can get on pump gas but someone here does.
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
blac94Z
Nov 4, 2015 01:59 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Slayer
Aug 17, 2015 03:55 PM
