rev limiter
Old Feb 14, 2003 | 12:05 AM
greg0101's Avatar
rev limiter
Anybody know what rpm the rev limiter is on a 96 SS. Also has anybody installed a recessed shift light in the dash before.
Old Feb 14, 2003 | 02:04 AM
ky94transam's Avatar
There is no rev limiter,just a speed limiter..
Old Feb 14, 2003 | 05:19 AM
94DROPTOPZ28's Avatar
Why would it NOT have a rev-limiter???
Old Feb 14, 2003 | 05:24 AM
anaik's Avatar
I believe the stock rev limiter is at 5800 rpm.
Old Feb 14, 2003 | 08:20 AM
97Z-M6's Avatar
where ever your geting your info stop
Old Feb 14, 2003 | 08:54 AM
anaik's Avatar
[QUOTE]Originally posted by 97Z-M6
where ever your geting your info stop [/QUOTE
You're saying, you can wind first gear to whatever rpm you want, right.
edit; I get it, you're saying there is a speed limiter for each gear.
Old Feb 14, 2003 | 09:16 AM
97Z-M6's Avatar
[QUOTE]Originally posted by anaik
he said thee is no rev limiter, just a speed limiter, and hes wrong. theres both
what im saying is i can wind first gear to the rev limiter. and not any father.
what im sayin is that there is a rev limiter.
Old Feb 14, 2003 | 09:38 AM
anaik's Avatar
My mistake, I should look at the posters username.
Old Feb 14, 2003 | 04:44 PM
OK I was wrong.No need to bash me or where I am from.Think this is tottaly uncalled for.
Old Feb 14, 2003 | 05:01 PM
BUBBA's Avatar
You are both right and wrong. There are no rev. limiters on Lt1s in KY and there are no speed limiters in Ky either.
Special pkgs. are made for Lt1s for moonshine runners in KY, Ala. Tenn.and Ark. and Miss.
Most other states, the limiters are set at 5800.
If you want to up the limit, you need to have PCM programmed or get an MSD-AL ignition. Or if you can find a real cheap HPP, that'll work too.JMHO
Old Feb 14, 2003 | 08:25 PM
Mtrhds94Z's Avatar
How would an MSD 6al box 'get rid of' a rev limiter?
As far as I know, you'd STILL have to program the stock one out [or higher]
Old Feb 14, 2003 | 08:38 PM
drop top steve's Avatar
You are correct, use an hpp ot lt1edit to move the rev limit up to 6900, then use the msd to set the new rev limit. Factory limiter shuts off fuel, msd and other aftermarket limit ignition.
G-BODYT56
Jan 14, 2022 11:14 PM
KYWes
Sep 26, 2015 08:49 AM
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
