Retainers on Comp 850-16 lifters...
Old Feb 23, 2006 | 03:09 PM
Javier97Z28's Avatar
Moderator
Below is a pic of a set of 850-16 lifters I just purchased for my heads/cam install. Just curious, aren't these the same type of square retainer clips (the gold part) that the Comp R's had? I thought these were an OK alternative using Snap-rings...
Thoughts? Should I send these back?
Old Feb 23, 2006 | 03:25 PM
SStrokerAce's Avatar
Re: Retainers on Comp 850-16 lifters...
Nope those will work.
Old Feb 23, 2006 | 03:27 PM
Moderator
That's what I was hoping to hear
I saw the pics of the Comp R's and saw all the broken parts to be underneath the lifter plunger I thought.. I guess that's the weak part on those?
Old Feb 23, 2006 | 08:13 PM
atljar's Avatar
The bad comp Rs had a Flat C clip looking thing.
Old Feb 23, 2006 | 08:38 PM
Moderator
Gotcha.. I noticed the stock lifters have the same setup as these.. for some reason I thought they were snap ring type.
Nothing to see here, carry on
Old Feb 24, 2006 | 07:07 AM
cehan's Avatar
That's what I used in my 383 and they work fine. FWIW, look real close at the pushrod cups. When I got my set from Summit, I saw that 4 out of the 16 had what looked like pits in the seat where the pushrod would ride. I called Comp Cams and complained about the quality. They said it would probably be OK, but had me return them anyway, and sent me 4 new ones. One other thing, the pushrod seat depth in the Comp Cams 850's are quite a bit different from the stock GM lifters, so after checking the rocker arm geometry, I ended up using 7.050" pushrods.
Chris
Old Feb 24, 2006 | 11:11 AM
firebirdStud's Avatar
interesting cehan... I guess Ill have to check into this more, as I have some chromemolly short pushrods, so I will check to see If I can use them with the comp 850 lifters...
Old Feb 24, 2006 | 01:07 PM
96speed's Avatar
Chris
Word to anyone reading: Always check pushrod length!
Ryan
Old Feb 24, 2006 | 02:13 PM
Chris
I don't know how you got it that short.... unless you decked the block a lot, milled the heads a lot and ran a really low lift cam.
Old Feb 24, 2006 | 11:09 PM
cehan's Avatar
I can't explain the "how"; but I used a comp cams Hi-Tech pushrod checking tool, and installed checking springs with two of the 850 lifters made solid with washers. After playing around with it a bit I was able to get a good pattern on the valve stem with the tool expanded 5 full turns. 6.8 + (5 x .050) = 7.050. I ordered comp cam Hi-Tech 7937 pushrods and checked the geometry again with them and it was good. The block is decked, I have Lloyds heads (LE1) and your cam (0.6XX lift with 1.6 Pro Mags) and using FelPro 1074 gaskets.
The one thing I noticed right off when comparing the stock GM lifters to the CC 850's is that the pushrod seat in the stock lifter is noticeably deeper, so it seems reasonable that if you use a stock length pushrod in the CC lifter it would be too long.
That's my story and I'm sticking to it
Chris
Old Feb 25, 2006 | 12:17 AM
Mkos1980's Avatar
FWIW, The Summit Brand Hydro Rollers for 104 bucks accually have a crane part number stamped on them. I have been using those with good results.
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
