Resistance values between Taylor and MSD wires
Old Jan 6, 2005 | 08:29 PM
rocmemphis's Avatar
Lightbulb Resistance values between Taylor and MSD wires
Thought some of you might like to see my findings. I tested the resistance (ohms) of equal lengths of Taylor 8mm spiro pros and MSD 8.5mm superconductors. Here is what I found:
MSD values...
#2 wire - 120 ohms
#4 wire - 124 ohms
#6 wire - 136 ohms
#8 wire - 145 ohms
Taylor values...
#2 wire - 842 ohms
#4 wire - 831 ohms
#6 wire - 938 ohms
#8 wire - 1003 ohms
Old Jan 6, 2005 | 09:14 PM
pntballty's Avatar
Re: Resistance values between Taylor and MSD wires
Wow thats a pretty big difference
Old Jan 6, 2005 | 11:15 PM
DavesLT1's Avatar
Does anyone have any #'s like this for the Accel wires.
That's a huge difference in ohms there.
Old Jan 7, 2005 | 01:20 AM
Spinner's Avatar
Those numbers mean nothing, 50,000 volts is going to take a much radically different path through a wire then 1mv.
Old Jan 7, 2005 | 04:21 AM
ss#1230's Avatar
QUE????
resistance is resistance right? assuming the volts are constant in his tests...
Old Jan 7, 2005 | 07:57 AM
izzyz28's Avatar
If you really think about it though, how many thousands of ohms of resistance are created by the air gap between the cap and rotor? Compared to that number, even a few thousand ohms a foot doesn't seem too bad for factory plug wires, while 800 ohms sounds downright awesome!
Old Jan 7, 2005 | 08:33 AM
BlownF1's Avatar
Closer to zero isn't necessarily better in this case...manufacturers try to balance resistance and noise suppression.
Old Jan 7, 2005 | 02:37 PM
Spinner's Avatar
Originally Posted by ss#1230
QUE????
No, it just doesnt work that way with this type of wire. You cannot compare numbers, an ohm meter is only useful for finding a bad wire (would be stupid high resistance compared to the rest), not for comparing one brand to another. Due to different wire design, resistance will vary among manufacturers, but any claims made as to a wire being better because of it are bogus.
Old Jan 7, 2005 | 10:33 PM
pHEnomIC's Avatar
Yeah resistance doesn't matter as long as its relatively low. Some companies put other things inside the wires to reduce radio interference to make sure there aren't any misfires.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
