Reprogramming the computer
Hi. I'm swapping the lt1 and 4l60e from a 94 z28 into a 68 chevy c10 pickup. The truck weighs about 4200lbs and has a 3.73 rear end. Is reprogramming the computer necessary? I've heard of lt1 edit and cats. Can I set the motor up with one of those? I have a laptop, and I'm pretty good with a computer. What are the chances the chip will get fried? Thanks.
You can get the PCm programmed from www.pcmforless.com for CHEAP. I had my car street tuned by Bryan at PCMFORLESS and it turned out great. He also does Mail Order Tuning.
Hope that helps, Claude |
You will at least have to change for the gear ratio. Tunercat or LT1_edit is a good way to go when you want to do stuff yourself. If not, you can still use your laptop and get a mail order tune that you can load yourself. http://madz28.com does this, too.
Just as luck would have it, my laptop doesn't have a serial port.. What kind of crap is that??? Anyway, Can I get a parallel or usb cable to do the job? What will the truck run like if I don't set the ecm up for 3.73? I'll be running it without a speedo for a while as it is. Will it affect the shift points since I have the 4l60e? Thanks!
TTT
