Replacing weatherstrip on SS ram air
Old Mar 20, 2004 | 02:05 PM
Revis_Racing's Avatar
Whats the pn# for replacement weatherstrpping for an SS ram air?
Old Mar 20, 2004 | 04:43 PM
craigffb's Avatar
The weather striping you can get from SLP pretty much sucks. I had the same problem when I got my SLP Ram Air HO hood. I just ended up getting some 3 inch window AC weather striping from a home improvement store. Way cheaper and works better.
Old Mar 20, 2004 | 10:58 PM
Yep, I went to Lowes and found the ac window unit foam weather stripping and immediately thought of it.
I bought some earlier today.
Its 1 1/4" wide and tall so it will seal pretty good, except for the fact its foam.
Won't air pass through it?
Old Mar 21, 2004 | 12:26 AM
craigffb's Avatar
It doesn't on mine. I tried to find something rubberized for a long time and I just couldn't find anything thick enough. I've been using the AC foam for about four years now. My box edges are a little wider than the one on the SS that is why I got mine in the 3". I also put it all the way around the box so the all the air goes in the box. Yours just had it on three side from the factory right?
Old Mar 21, 2004 | 12:28 AM
right. i'll see if i can fix that tomorrow.
Old Mar 21, 2004 | 12:33 AM
craigffb's Avatar
You'll need to get some good glue to hold it on. Wish I could remember what I used.
Old Mar 21, 2004 | 12:40 AM
i bought indoor/outdoor 2sided tape.
Old Mar 21, 2004 | 12:43 AM
craigffb's Avatar
That may work. I got the glue from a friend of mine, it was a thick yellow glue. He called it "gorilla snot", not sure what it's really called.
Old Mar 22, 2004 | 12:00 AM
I installed the weatherstripping earlier. The two sided tape worked pretty good. I seal the box all the way around this time.
Old Mar 22, 2004 | 01:40 AM
97SS0594's Avatar
gorrilla glue, is the products name i beleive your refering too. its awsome!!! you can get it at any true value harware store!! once its dry its like cement youll never get it off!!
Old Mar 22, 2004 | 09:31 AM
BUBBA's Avatar
Just curious. How can you put it all the way around without impeding the flow?
Old Mar 22, 2004 | 10:30 AM
craigffb's Avatar
The air flow is coming from the hood scoop, not the inside of the engine bay. The same way it is on a Factory WS6 LT1 car. It also has a completely sealed air box.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
LT14LIFE
Feb 9, 2015 09:35 PM
rjc1629
Jan 27, 2015 10:46 AM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
