Replacing water pump drive seal question...
Old Apr 20, 2004 | 03:17 PM
CeeBee94Z's Avatar
Ok well I am replacing my water pump drive seal tonight because its leaking like crazy after the cam swap....my question is what is the best way to put the seal on assuring that it doesn't tear? When I installed it the first time I did it after the timing cover was on and it still tore apparently. So I was wondering if there was an easier way to do it.
Thanks guys
Old Apr 20, 2004 | 09:16 PM
CeeBee94Z's Avatar
TTT
Old Apr 20, 2004 | 10:36 PM
Ever try a search? There is a trick to putting the seal on that has been explained countless times. Use the coupler or a deep socket to slide the seal on first.
Old Apr 20, 2004 | 10:39 PM
my94blackz's Avatar
Like Mr. box said you need a socket. I took the water pump shaft that connects the 2 gears, lubed it up well, and stretched the seal with my finger a lil and slide her up close then knock it home with a socket.
Old Apr 20, 2004 | 10:44 PM
CeeBee94Z's Avatar
I did it that way the first time, that is why I posted again to see if anyone had any other ideas...
Thanks though
Old Apr 20, 2004 | 10:56 PM
Thanks though
You just have to be careful. If you stretch the seal out like my94blackz said, it will give it a little more room to go on. The seal will not hold the memory of the stretch for long and should seal up fine.
Old May 5, 2004 | 06:17 AM
94DROPTOPZ28's Avatar
I just used a deep well 1/2 inch socket and lubed it up with oil (the socket) and slid the seal onto it and placed it over the shaft and pushed it into place, and then took and bigger deep well socket and a rubber mallet and very slowly hit the seal into place & it worked great for me the first time...
BTW: No leaks and the seal didn't tear
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
