Replacing Oil pan seal, hard?
Re: Replacing Oil pan seal, hard?
Originally Posted by Loadre
HAHAHHAHAHA, no.
DO NOT even try this without a cherry picker. Jacking it up by the hub is asking for the motor to fall on your hands. Trust me I tried it and about lost a couple fingers. Take the motor mount thru bolts out, take the bolt off the tranny mount and raise it up with a cherry picker as far as it will go.
Or you can do it the hard way and try and snake the gasket around in one piece and get oil all over it, have it not seal, and have to do it again. To do it right you need to take brake cleaner to all mating surfaces.
stockssn2o
May 25, 2015 08:54 AM
