Replacing just the lifters
Old May 23, 2005 | 02:25 PM
luckyou03's Avatar
Can I pull them out with just the valve covers off.. or does the intake manifold have to come off too? I need to know before I start so I get all the gaskets I need.
Adam
Old May 23, 2005 | 02:29 PM
nathan96's Avatar
Re: Replacing just the lifters
Are you doing it for maintenance, because once you get the lifters out you might as well do rocker arms and pushrods at the very least too. You have to remove the pushrods, loosen the rocker arms, the intake manifold, the lifter spider and guides then they will just slide out. Check http://shoebox.com
Old May 23, 2005 | 02:37 PM
luckyou03's Avatar
I'm replacing them for maintenance as well as the push rods, but I thought the rocker arms would be fine?
Old May 23, 2005 | 03:10 PM
nathan96's Avatar
They probably will be, but why not upgrade while you have everything apart?
Old May 23, 2005 | 03:15 PM
luckyou03's Avatar
I'm buying wheels tommorow and this problem just came up. I got kind of limited funds, so upgrading will be later on.
HectorM52
Jul 30, 2017 11:46 AM
Sauced
Apr 12, 2015 10:18 AM
dfarr67
Apr 10, 2015 07:44 PM
jj_burchiel
Mar 5, 2015 07:05 AM
jayblev95
Dec 1, 2014 06:55 AM
