replacing head gasket
Old May 25, 2011 | 12:42 AM
DaveHuss's Avatar
Can I remove the heads to change the head gasket with the motor in the car? Should I just do 1 or both heads? 1995 z28 with 383 in it THANKS!!
Old May 25, 2011 | 01:04 AM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
Re: replacing head gasket
Yes you can do it with the motor in. I would do a test to make sure the other side isn't losing compression and if not then I would only do one as long as you are using the same gasket
Old May 25, 2011 | 09:25 AM
DaveHuss's Avatar
Can aynyone walk me through how to pull the heads while engine is in the car? I am thinking maybe I should do both while I'm at it. Just a question here: Has anyone ever used therma gasket or steel seal?
Old May 25, 2011 | 09:31 AM
calaban's Avatar
I'd go ahead and do both sides while you are in there. I mean you already have the intake off and everything. The kit you get will probably come with both head gaskets anyways.
Old May 25, 2011 | 11:47 AM
DaveHuss's Avatar
What is the BEST head gasket?
Old May 25, 2011 | 11:51 AM
RamAir95TA's Avatar
OEM from GM.
Old May 25, 2011 | 09:39 PM
DaveHuss's Avatar
Hey RamAir: Do you have any answers to my above questions
Old May 26, 2011 | 08:23 AM
95TA04GOAT's Avatar
Drain the coolant from the block and radiator. Unbolt the accessories and brackets from the block/heads. Remove the air pump and coil / icm. Remove the intake manifold. Remove the valve covers, rocker arms and pushrods making sure you organize them in a manner which will allow you to reinstall them in the same spot they were removed from. Remove the exhaust manifolds. Disconnect the ground connections on the back of the heads. Unbolt the heads following the proper sequence and lift off.
It's easier said then done but that'll get you started in the right direction.
Old May 26, 2011 | 10:35 AM
Final03's Avatar
The best gasket Is either felpro or MLS gaskets but those are more for people with porting done on their heads as it can be a custom made gasket set. Its a really thick gasket but it works.
Old May 30, 2011 | 12:19 PM
DaveHuss's Avatar
guess i shouldnt have bought my daughter this car, had no idea how much power it had until after i bought it. Now she's in love with it. ARRRGH! Should probably replace 383 with 350 but hate to spend so much on another motor
Old May 30, 2011 | 12:36 PM
95TA04GOAT's Avatar
Sure you could find someone to sway you their stock 350 + some cash for your 383.
Old May 30, 2011 | 12:46 PM
96capricemgr's Avatar
I would sooner use a junkyard engine than a budget rebuild or "budget performance" engine. If it is having head gasket troubles that should tell you the work is questionable, probably all of the work.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
