Replacing Head gasket??
Ok I have to fix my intake manifold leak. Once i have the intake off, how much harder/longer would it take to replace the head gaskets? I MIGHT have a head gasket leak, but im not sure.
ANy pics of doing the head gasket, any special tools needed?
make sure you figure out the symptons to be a blown head gasket. Its not a fun task, since it requires removal of the exhaust manifolds...not fun.
other than that, I havent found the need for special tools yet
yea i would try to make sure you have a head gasket leak before you take the heads off ... be positive , because its not something you want to do unless you have to
.. only reason im doing it now is because i got 'new' heads , to me it's all fun as hell.. but only because it's a new part
