replacing head bolts possible
Old Sep 20, 2007 | 09:28 AM
tim95z28's Avatar
Without removing the heads, one bolt at a time?
When I rebuilt my engine (383) I did not realize that I needed new bolts. I am running the original bolts (60k) miles, and am not having any problems.
I have some new arp bolts, and want to replace the old ones. Should I just leave it alone, or can I replace them one at a time? I don't want to pull the head and get new gaskets etc.
Thanks!
Old Sep 20, 2007 | 09:40 AM
pizzi-man's Avatar
The age old saying " if it aint broken why fix it" Save your bolts till you need to change the head gaskets and have a beer instead.
Old Sep 20, 2007 | 09:53 AM
Don 97 SS's Avatar
Good advice. Leave them alone as you may be inviting trouble.
Old Sep 20, 2007 | 10:13 AM
tim95z28's Avatar
Secondary reason; I was getting some oil leaking around the rocker studs (ported heads) and wanted to reseal the center head bolts.
Old Sep 20, 2007 | 10:14 AM
rskrause's Avatar
Moderator
You can do it, but I am not sure it is a good idea. I have never done it, so I am only speculating.
Rich
Old Sep 20, 2007 | 04:23 PM
onebadponcho's Avatar
If you do replace them, make sure you drain your antifreeze first. Were the bolts you re-used torque-to-yield bolts?
Old Sep 20, 2007 | 04:34 PM
tim95z28's Avatar
I guess, they were the original 95 bolts.
Old Sep 20, 2007 | 04:36 PM
White96Z28's Avatar
I would actually change them... I'm pretty sure (but someone CMIIW) that the original head bolts are torque to yield bolts, which means they are no good now that they've been reused.
Old Sep 20, 2007 | 04:46 PM
dangalla's Avatar
i never did this on my camaro,
but i did do this on dsm and i also did it on my buddys evo, just do one at a time and you should be fine
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
