replacing clutch
Old Aug 11, 2003 | 10:59 PM
  #16
NVetro's Avatar
ehhhhhh SLP setup is pretty close to stock. I would say just get the $45 OEM flywheel u can get :-)
Old Aug 11, 2003 | 11:08 PM
  #17
Quick96Z's Avatar
Hey guys, keep on posting your thoughts, but all i have to say is to all you people that know way too much for your own good. You guys really helped me out.
here's the run down on my project for this weekend...
SLP clutch and pressure plate kit...$372.85
cheap new flywheel from checker...$45
one piece rear main from checker..$13.50
some enlightening beverages for me and a buddy...$20
like one of you said, "hey, it's only money"
thanks for the help,
trav
Old Aug 12, 2003 | 12:13 PM
  #18
kgkern01's Avatar
NVetro, like I said, their customer service IS great. It is just their build quality or quality control that sucks. Both Stage 3 clutches that I got were 6 puck clutches of their new design. Their spring section is not heavy duty. Compare it to a stock center and then compare to their four cylinder models. It uses the EXACT same center section piece (exact, not similar) as their small four cylinder clutches, this is why they won't last on our cars. If they redesigned their clutches that used a spring section beefy enough to handle and last in our cars I would go back to Spec because they do have good customer service, except for the fact that they wouldn't acknowledge that I had a bad clutch and my car wasn't at fault. Once I told them how I replaced everything last time, they paused, then said well, something isn't aligned because the clutch isn't just going to blow the springs.
Old Aug 12, 2003 | 09:59 PM
  #19
my94blackz's Avatar
Is the whole lt4 kit worth buying?
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
Jazsun
Dec 29, 2014 12:14 PM
