Replacement TB plate for AZS&M Monoblade?
Old Oct 24, 2003 | 08:31 PM
jimlab's Avatar
Like it says... if you don't want to advertise for Arizona Speed & Marine on top of your 1300 cfm Monoblade throttle body, where do you go?
MBA (Mallory Billet Aluminum) seems to only have plates for stock throttle bodies, but I've seen someone else's engine equipped with a Monoblade that had a different plate. They do offer custom engraving, though.
I'd like something like "396" or "6.5L" or even "LT1", and I'll have one made if I have to. Actually, I just bought a Grizzly G1006 milling machine, so that might be a good first or second project, but it'd be nice not to add something else to the list of things I have to make myself.
Thanks!
Old Oct 24, 2003 | 08:51 PM
JWINN's Avatar
I do believe Thunder Racing offers different TB plates from various colors to engravings.
http://www.thunderracing.com/index.c...ategoryid=1005
Old Oct 24, 2003 | 11:41 PM
jimlab's Avatar
Thanks Jim, but those are the same Mallory Billet Aluminum plates I was talking about, and they have the stock throttle body bolt pattern. The Monoblade has a different bolt pattern with the center two screws offset to the left.
http://home.gci.net/~jimlab/images/E...d/P1190035.jpg
Old Oct 25, 2003 | 05:08 AM
jkipp84's Avatar
Man, what an engine!
Maybe they can use your plate as a guide (or you can try sending some dimensions or something) to make one from a blank & engrave it for you.. No harm in asking!
Old Nov 14, 2003 | 03:36 AM
jimlab's Avatar
I decided to "roll my own"...
http://www.rx7club.com/attachment.php?s=&postid=2336754
http://www.rx7club.com/attachment.php?s=&postid=2336759
http://www.rx7club.com/attachment.php?s=&postid=2336770
Now... I wonder if I can carve "6.5L" in the top of another one without totally screwing up about 4 hours worth of work.
Old Nov 14, 2003 | 03:54 AM
Tair's Avatar
damn I gotta get me one of those engines too!
Old Nov 14, 2003 | 07:02 AM
kmook's Avatar
Advanced Tech Moderator
Very nice Jim!
Now i know who to go to for all the custom stuff i'll need
Old Nov 14, 2003 | 08:54 AM
bn_bullet's Avatar
Jim,
I too had this problem and I contacted Paul Roswell at MBA (e-mail: proswell@malcams.com ). They made a TB plate to fit the AS&M throttel body for me and even custom engraved it. Paul had drawings done of the engraving and e-mailed them to me for approval prior to engraving the parts. I must say that the finished product is outstanding and Paul's customer service was top notch. It wasn't that expensive either. The total for the plate was about $80.00. I also had them make a water pump cover with custom engraving and it too is very nice. My post may be too late for you but I thought I would post in case others are looking for the same thing.
Regards,
Brian
Old Nov 14, 2003 | 09:43 AM
NOMAD's Avatar
Too late here too I guess. I would have scratched ya one up for free Jim-bob Nothing fancy for free though
-Shannon
Old Nov 14, 2003 | 11:45 AM
94 CAMRO Z28's Avatar
That engine is a work of art! Is that a Hogan <--sp? racing intake? How much did it cost and what kind of gains can be obtained from it?
Aaron
Old Nov 14, 2003 | 12:45 PM
jimlab's Avatar
No problem, Brian. I may have them do one for me anyway, but I needed a good first project for my new milling machine, and figured it was better to start small. It turned out pretty good considering I've never used a mill before in my life.
Old Nov 14, 2003 | 12:50 PM
jimlab's Avatar
Yep, Hogan's Racing. $2,850, which included the nitrous bungs and a distributor hole at the back, which it turns out I'll be using for an MSD cam sync stub to solve my ignition problems.
There are a few more images here...
http://home.gci.net/~jimlab/images/Intake/
Precisely how much horsepower it was worth, I'll never know, because it was a requirement for my AFR 215cc raised runner heads and hood clearance. I do know, however, that it makes good power, even with the Opti-spark crapping out...
http://www.rx7club.com/forum/attachm...postid=2206653
Old Nov 14, 2003 | 01:07 PM
jimlab's Avatar
From a fan on the RX-7 Club forum...
Jim that milling job isnt going to hack it..
Firstly that stupid plate is extra weight!
Secondly that could be done with a $20 drill and a hacksaw JUST AS WELL!
You better step it up cause that aint impresive
Old Nov 15, 2003 | 07:59 PM
arnie's Avatar
Re: Replacement TB plate for AZS&M Monoblade?
http://www.enginedressshop.com/
Old Nov 15, 2003 | 09:12 PM
OneFlyn95z28's Avatar
Hehehe Yup Paul would have cut you one.
Right now I have a "More" and "TPIS" plate on mine. My intake looks to be a little taller then yours. Might be the 18* heads
Looks like we will have to have a Kirkland Vs Redmond race hehehe
