replaced waterpump, car wont run
Old Oct 27, 2004 | 02:39 PM
blackcamaroz28's Avatar
about a week ago my waterpump went it was spraying coolant out of the weeping hole on the waterpump. the car ran i noticed it pulling into my driveway so i shut it off and left it. i bought a new waterpump and did the install, and now the car just cranks over and wont start. anybody have any ideas what is wrong? could it be the opti?
Old Oct 27, 2004 | 02:44 PM
Project Ghost's Avatar
Re: replaced waterpump, car wont run
Sounds like the opti.
Old Oct 27, 2004 | 02:50 PM
marshall93z's Avatar
ive had two waterpumps do that, but never hurt the opti...i ran like crap while it was leaking though!
Old Oct 27, 2004 | 02:55 PM
BlownF1's Avatar
Check the two connections on the coil. One is the coil wire itself to the opti, and the other is the control harness to the PCM...make sure both are seated securely.
Old Oct 28, 2004 | 10:00 AM
dont kno whats going on here checked the coil wire at both ends and its securly plugged. all the other plugs and such are securly plugged to. maybe i got water in the opti??
Old Oct 28, 2004 | 10:24 AM
i dunno if anyone knows what im talking about, but do u kno when you turn the key on the camaro makes like a roboty sound, im not sure what it is, but now when i turn the key on it kinda sounds like a grinding sign. could this be the reason? if anyone has any idea please let me kno. thanks in advance
Rich
Old Oct 28, 2004 | 10:33 AM
Rich
Old Oct 28, 2004 | 11:24 AM
its the fuel pump priming the fuel pump right? could that be the prob
Old Oct 28, 2004 | 11:30 AM
Z95m6's Avatar
That sound is the fuel pump. It seems odd that it would just go out like that but check the fuel pressure.
Old Oct 28, 2004 | 12:42 PM
clarkysz's Avatar
My friend had the same problem and it was the opti.
Old Oct 28, 2004 | 06:08 PM
maybe it is the opti, i'll tell you one thing, if it is im gettin the delteq, no way im taking that waterpump off again and delteq is way worth the cost. plus i can knock off plugs and wires on the to do list. im gunna bring it to a mecanic whose goin to check for spark and fuel pressure so we'll se what happens
Old Oct 28, 2004 | 06:16 PM
Fastbird93's Avatar
Pull a plug and ground it while someone cranks the car to check for a spark. Are you sure you plugged the opti back in??? I know it sounds stupid, but stranger things have happened.
Old Oct 30, 2004 | 03:11 PM
ok.....today i pulled a plug and check for spark.....no spark, so i checked all connections from the opti, the ignition module, and the coil and all are secure. its gotta be the opti.....
Old Oct 30, 2004 | 07:41 PM
Ryan94ZA4's Avatar
Hopefully, the opti was not pulled when the water pump was replaced. That seems kinda like a waste of time to me.... Could be the opticrap...
RYan
Old Nov 1, 2004 | 08:10 PM
well i think i finally found the problem. took the opti off, found that a few metal terminals snapped off where the optical eye plugs in on the opti. bad way to spend a couple hundred bucks, hope it solves the problem. thanks for the posts, gettin the part tomm tell you if i get it up and running.
Rich
pologreen97z
Dec 2, 2014 10:42 AM
jayblev95
Dec 1, 2014 06:55 AM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
