Removing Rad
Removing Rad
I'm dropping in a rad I got from www.sybersport.ca
$450 u.s.
What tools do I need?
How long does it take?
Anything to watch for?
Really fricken cold out so I don't want to get under the car and check right now.
Can't find my Haynes either.
Anyone have a step by step guide on the net?
$450 u.s.
Radiator isnt held in by anything but the shroud above it.. ya know big black plastic peice.
Use a socket wrench to get the 3 bolts out. then get under the car, unplug the fans, pull them straight up, and wala, there's your radiator.
Didnt see ya sig, so if ya have A4 your tranny lines will run into it, remove and plug those.
Take a flathead and loosen your hoses, and pop em off. you have an upper and lower, as well as the overflow tank.
Have fun man
Have fun man
Originally posted by Gripenfelter
So no special disconnect tools needed for any of the fittings?
No bolts holding the rad fans in? Everything slides up?
This is an aftermarket 4 core all aluminum rad Trey.
With my stock rad I was running right under the red.
Other rads on the net of the same quality were $550-$600.
Thanx Shoebox & Bawls!
weird, my 383 runs just as cool as the 350
you sure its not a water pump, clogged coolant line or air in the system?
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
