Removing motor mount
Old May 3, 2003 | 03:43 PM
Van5150's Avatar
Removing motor mount ?
To raise my motor a few inches on pass side, to get to spark plugs, do I remove the one long bolt on the motor mount, or the 3 little bolts to the block ?
Damn my big fat hands,, where is Jenny Craig.,
Old May 3, 2003 | 04:06 PM
johnpsz's Avatar
Usually just the one long one, but I know a couple of guys that say the bolts on the block are easier to get to. I would just do the one myself then put it back in the opposite way so it would be easier the next time.
Old May 3, 2003 | 09:42 PM
chevroletfreak's Avatar
I had no problem getting to the longer bolts. 1 on each side.
Old May 4, 2003 | 11:29 AM
Van5150's Avatar
Forgive my stupidity, how do you push it out ?
Old May 4, 2003 | 11:43 AM
johnpsz's Avatar
This is how I do it, get the jack set up on the bell housing and start to lift it slightly to relieve the pressure/bind on the long bolt and push/pull it out easily. It should be that easy for you also.
That is what you were asking right?
HectorM52
Jul 30, 2017 11:46 AM
rjc1629
Jan 27, 2015 10:46 AM
mattszm6
Dec 14, 2014 07:09 AM
