Removing A.I.R. pipe intact?
Old Jan 13, 2004 | 01:43 PM
  #16
CamaroBoy96Z28's Avatar
Originally posted by Ponykillr
I removed the AIR pipe without taking out the Compressor. The Compressor is a whole nother chore by it self and I dont recommed you do it unless you want to leave it out. Dont take the compressor out to remove the AIR pipe just cut the pipe.
If you want to remove your A/C and heat on the other hand this will be a good time to do it if you want to take out the compressor. All that stuff was built to go together but not come apart. Like I say GM says cut it. You know If GM wont attempt to try to get the compressor out its very hard.
That still leaves the problem of the bolt. How did you get at yours? Or did you just cut it in two spots and leave a small section of the pipe that isnt visible? I thought of that as an absolute last resort, b/c my pipe is just sitting there and i'd like to get it out.
Old Jan 13, 2004 | 01:48 PM
  #17
LWillmann's Avatar
I went at it from the underside of the car in front of the k-member with a shallow socket, a universal joint and an extension...
I got the bolt out, got the pipe out of there, then put the bolt back in.
If you cut the tube at the bottom of the u bend below the crank, then cut it on the passenger side (from the top) where it bends toward the block (cut it as close to the bottom of that bend as you can), you can wiggle and pull the tube out the bottom of the car once the bolt in the block is out. I made an extra cut that I didn't have to in hopes of pulling the tube out the top, but it was easier to work it out the bottom.
Old Jan 13, 2004 | 01:52 PM
  #18
Bastardcat's Avatar
There are 2 10mm bolts holding the compressor bracket to the compressor and 1 14mm bolt that holds the compressor bracket to the block, with the metal tab of the A.I.R. pipe in between. I removed the 2 10mm bolts to get to the 14mm bolt.
Old Jan 13, 2004 | 01:58 PM
  #19
Thanks, that doesnt sound all that bad. I'll have to give it a shot.
drptop70ss
May 4, 2015 08:22 PM
rick350
Mar 14, 2015 10:46 PM
alphaauto
Jan 23, 2015 07:42 AM
thenewkid
Nov 18, 2014 12:57 PM
Jul 4, 2005 05:00 PM
