Removing Fuel Injectors!!
Old Apr 4, 2006 | 12:08 PM
johnny3986's Avatar
Well, push came to shove, came to broken schrader valve.
From there, the journey continued to an overnighted replacement off the board.
When I take off the injectors, do I have to worry about o-rings anywhere? I haven't ever dont this before, and I will have to reuse the o-rings. Are there o-rings in the fuel rail or any down in the manifold?
Even better, is there a fast way to slap off the fuel rail and leave the injectors in the manifold?
Replacing injectors or waiting for replacement o-rings is out of the question, but if O'Reillys or AutoZone carries replacements, I could get some...
Anyways, the more feedback left the better since I am supposed to be at work right now, and I will come back at 6pm to check this, so everyone list hints, suggestions, etc.
THANK YOU IN ADVANCE!!
Old Apr 4, 2006 | 12:10 PM
fast96lt4's Avatar
Re: Removing Fuel Injectors!!
yes, Oriely's or any auto parts store should have o-rings.
Old Apr 4, 2006 | 12:23 PM
94EvilZ28's Avatar
Yeah there are orings on the top and bottom of injector...you could reuse them...but make sure they arent torn or worn out...
Old Apr 4, 2006 | 12:28 PM
MeanGreen97Z's Avatar
Id replace them! They are cheap and there is no reason to reuse those old ones.
AdsoYo
May 2, 2018 03:21 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
