Removing EGR
Old Sep 13, 2003 | 10:15 PM
ProjectTranzAm's Avatar
Removing EGR
What good does it do?
Old Sep 13, 2003 | 10:33 PM
1msfyter's Avatar
Me too! And can you just block off the pipe at the exhaust pipe and leave everthing in tact? the heast should godown too right?
Old Sep 13, 2003 | 10:58 PM
AFAIK, there are no performance benefits. Some people do it, because they buy headers that have no provisions for the feed pipe and other people do it because they want to and still others because it "cleans up" the engine compartment (not that it does IMO).
I think some of the rationale is that the LT4 did not come with an EGR and it had more horsepower (therefore people think "no EGR-more horsepower"). However, it did not require the EGR for emissions because of the different cam it had.
Old Sep 13, 2003 | 11:03 PM
Josh-'04 GTO's Avatar
I think that hit the nail on the head. Since the "LT4" cam had more overlap than standard "LT1" cams, GM Powertrain deemed EGR redundant and unnecessary. If you run an aftermarket cam, odds are you will have enough overlap to accomplish the same thing.
Old Sep 13, 2003 | 11:13 PM
Another thing is that it only operates in part throttle situations anyway, so there is no need to worry about any power loss when you need it most (WOT).
Old Sep 13, 2003 | 11:21 PM
nitropatch's Avatar
when you block the EGR the motor wil get 5-10 degrees hotter at least thats what it did on mine, might get 1-3 more hp because thats less stress on the motor from recycling the air, and fast it gets out of the motor. this is all that i have realized on mine, might be different on the rest of your cars.
Old Sep 13, 2003 | 11:28 PM
pelebkf's Avatar
I blocked mine until just recently when I found that the heat was being tranmitted to the aluminum intake through the block off plate. Thus causing a manifold leak which was a pain in the butt to change. I you block it you need to block it at the exhaust pipe not the manifold to reduce the heat. But like shoebox said it really doesn't help you to block it in the first place.
Old Sep 14, 2003 | 12:44 AM
OZ DREAMER's Avatar
What about the air pump(?) that black thing that has wires going to it and hoes, what do you do with that?
Old Sep 14, 2003 | 01:02 AM
notstock4long's Avatar
I want to do it only to make the engine bay a little less crowded, and because it is ugly and wierd looking. I would also like to know what to do about the AIR pump. Can you just block off the hose that goes to the intake elbow? And what about the wires on it?
Old Sep 14, 2003 | 01:08 AM
PhoenixCIS's Avatar
my lt4 intake has egr
Old Sep 14, 2003 | 01:09 AM
CamaroBoy96Z28's Avatar
I have deleted both AIR and EGR. The EGR has already been explained so I wont say anything about that. For the AIR pump, remove the 3 bolts holding it to the bracket, block the hole in the air box/CAI with tape or 5/8" vacuum cap. Thats all there is to it and enjoy your new SES light and room your freed up.
Old Sep 14, 2003 | 01:11 AM
But what about the wires? Did you just unhook them from the pump and leave them plugged in?
Boss002
Jan 20, 2016 12:17 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
