Removing carbon from cylinder head
Old Nov 8, 2008 | 01:49 PM
dubbsix's Avatar
Looking to sell the heads off my LT1, but wanted to clean them up a bit.. is there a drill attachment i can use to clean off the carbon without compromising the sealing surfaces?
Old Nov 8, 2008 | 02:00 PM
Green96Z's Avatar
I wouldn't use a drill attachment. Carb cleaner, a razor blade, and elbow grease is really all you need. Whatever you do, DO NOT use Scotchbrite. You can get an uneven deck that way.
Old Nov 8, 2008 | 02:04 PM
LaredoZ28's Avatar
On the heads i've cleaned up I use varsol. its a cleaning solvent that can be reused. its like 30 bux for 5 gallons.
Old Nov 8, 2008 | 02:06 PM
dubbsix's Avatar
Oh.. the carb cleaner wil remove the build up carbon on the combustion chamber? they arent horrible, but i guess i'd like to make them more sellable. What exactly will i be applying the elbow grease to? Do i just use a rag or something?
Old Nov 8, 2008 | 02:16 PM
LaredoZ28's Avatar
rags work fine. you can also use parts cleaning brushes. they are similar to detailing brushes for interiors.
Old Nov 8, 2008 | 02:48 PM
dubbsix's Avatar
Just hit it with some brake cleaner and it got spanking clean...
Old Nov 8, 2008 | 03:29 PM
MachinistOne's Avatar
To clean out the chambers you should use carb-clean, a dental pick or flat blade screwdriver and a wire brush(hand held) to clean the deck you can use a putty knife, razor, chisel...anything with a flat-sharp edge that will scrape up gasket and carbon without scratching the deck. To finish up the deck you can use a green scotch brite pad with WD-40 and lightly swirl it around to get rid of the little stuff - it's when people use the drill attached abrasive disks that the deck get's ruined.
Now that you have cleaned the deck you may see indentations(brinelling) around the chambers where the fire-rings sat, or water etching/corrosion - this would mean the heads need to be surfaced...pretty much any aluminum head should be surfaced after it has been removed after any substantial time on a motor....obviously let your buyer do this, also I don't think you will get any extra money by spending the time to do carbon removal. Personally I would rather have heads sold to me as-is.
Old Nov 9, 2008 | 06:46 PM
Z28LT1_Just_Nasty's Avatar
Eh I used a toothbrush and some citrus cleaner. Maybe it was simply orange? I can't remember. Worked pretty well actually.
Old Nov 10, 2008 | 12:49 AM
luckyou03's Avatar
I use aircraft paint stripper. The heads will be cleaner than they were new from the factory.
Old Nov 10, 2008 | 04:40 AM
96m6lt1's Avatar
or you can pay a machine shop 30.00
Old Nov 10, 2008 | 08:13 AM
MeanGreen97Z's Avatar
I like this far better! My time is valuable to me and spending a few hours cleaning this stuff sucks. I let the machine shop clean them to like new in the parts cleaner.
Old Nov 10, 2008 | 12:21 PM
derrickgott007's Avatar
I worked in a NAPA mqchine shop and i loved the parts cleaner machine....pressurized hot solvent will make damn near anything look new. especially aluminum heads and blocks! I put a rusty antique iron in there for ****s and giggles and it looked brand new!
Napa is usually like $10 to $20 depending on size of parts washed. a set of heads was usually $18. but that was 12 years ago now! lol
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Elcojoe
Nov 17, 2014 10:27 PM
