Removing air pump what to do with empty holes in headers
Old Feb 14, 2003 | 11:40 PM
ryker77's Avatar
I'm goining to install some edlebrock headers and at the same time I'm goining to do away with the air pump system. What is the best method of capping the holes left on the headers?
I've read were some people have just welded them up. Thats not an option for me because I don't want to permantly screw things up.
I would like to just screw on some caps. or put a temp sending unit in it place.
Old Feb 14, 2003 | 11:59 PM
Smokn '94 Z's Avatar
Lightbulb
Put a plug in them. You have to figure out the I.D. of the AIR tube orfices. My FLP's were 3/4 -13" I believe & I made them at work. If you look at my pics in the sig you will see them. Or you can go to the hardware store & find something also. Use some High temp sealant too..
Old Feb 15, 2003 | 12:52 AM
Trans-Am's Avatar
Take your header to your local hardware store/home depot and ask for plugs! I think they are M-22 (metric size). Check it otu bro and use some sealant!! ~rob
Old Feb 15, 2003 | 02:44 AM
ryker77's Avatar
Thanks for the help.
Old Feb 15, 2003 | 05:04 AM
anaik's Avatar
What year is your car. Different years, different plug sizes.
Old Feb 15, 2003 | 06:27 AM
RamAir95TA's Avatar
You could JB Weld a quarter over each hole.
http://www.worldisround.com/photos/321/73.jpg
Old Feb 15, 2003 | 06:59 AM
baron4406's Avatar
You could get some Hooker LT's
Hey RamAir95TA- Do all your buds now call you "Fifty Cent"
Old Feb 15, 2003 | 07:08 AM
RamAir95TA's Avatar
Yeah, best fifty cents I ever spent!
Old Feb 15, 2003 | 08:38 AM
Hyperspeed97z28's Avatar
what plugs for a 95 style header "dynomax shorties"??
Old Feb 15, 2003 | 08:48 AM
anaik's Avatar
The '94-'95's use an M22 drain plug.
Old Feb 15, 2003 | 08:59 AM
Good deal, some "know it all on here" had me order the wrong plugs.....
Old Feb 15, 2003 | 11:12 AM
anaik's Avatar
That's provided that the Dynomax use the fittings that go to the '95 exhaust manifold. For example my FLP's for my '95 used AIR fittings from a '96-'97. Those are smaller. That size is 3/4 X 16. M18 will work but they are a little sloppy in the thread. I don't want to give you the wrong info. Aren't Dynomax the same as FLP?
Old Feb 15, 2003 | 11:28 AM
Good question! I'm not sure that is why I'm asking I tried some plugs for the 96-97 I believe and they didnt work? does napa have m22 plugs?
Old Feb 15, 2003 | 11:51 AM
Lightbulb
DynaTECH are the same as FLP's. Not Dynomax.... My FLP's were 3/4-16" as you stated too.
Old Feb 15, 2003 | 11:53 AM
96 WS6's Avatar
I'm using a 5/8 angled cap. Simple item that any hardware store will have for under a buck.
