Removing AIr on OBDII car?
Old Apr 17, 2004 | 07:22 PM
apached_driver's Avatar
Ok,
All the searches I just ran left my OBD II self with some questions?
Header block off nuts... 22mm or 18mm?
Where do you get block off plates?
What about the hole in the back of the passenger manifold, what size is that?
Error Codes, any way to clear em off for good?
Will it hurt the CATs if they're still there?
Jack
Old Apr 18, 2004 | 01:25 PM
Exclamation No thoughts?
TTT
Anyone?
Old Apr 19, 2004 | 04:42 PM
Bueller????
TTT
Old Apr 19, 2004 | 04:47 PM
drewstealth's Avatar
I just got my headers installed(hooker LT's) and there are no air pump fittings. So they ditched my air pump. So far it hasn't thrown any codes.
Old Apr 19, 2004 | 04:52 PM
LWillmann's Avatar
Re: Removing AIr on OBDII car?
Originally posted by apached_driver
Ok,
Jack
1) Not sure, I removed my AIR and EGR stuff when I did header install. My headers have no such connections.
2) You can order a blockoff plate for the valve itself from a dealership, or Jason Cromer, or Dal, et. al. It's the LT4 EGR valve blockoff plate.
3) To block for the pipe on the back of the manifold, you can simply cut the pipe and use the plate there, with a piece of aluminum can RTVd to it, then bolt the plate back to the intake. You should also be able to do this same thing to the EGR valve if you don't want to buy a plate.
4) Error codes will continue to come back until it's programmed out of the PCM by LT1 Edit. You can contact Madwolf or PCMforLESS or any number of other qualified tuners to handle this for you, or you can purchase LT1 Edit and do it yourself.
5) I can't answer this one becuase I removed my cats when installing my headers. I don't think it would hurt, just make them take longer to come up to operating temps... But don't quote me on that.
Good luck!
Old Apr 20, 2004 | 10:15 AM
Anymore input?
TTT
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
BLOWNBIRD
May 28, 2003 01:02 AM
