Remove PS Pump/Pulley to change Water Pump?
Old Apr 18, 2008 | 10:25 AM
19z28camaro02's Avatar
Do I have to remove the power steering pump/pulley to change the water pump? I noticed the center bolt on the passenger side looks like its behind the pulley.
Old Apr 18, 2008 | 10:31 AM
ss.slp.ls1's Avatar
No, you don't have to. Use a swivel head extension or something similar and you should be good to go.
Old Apr 18, 2008 | 10:35 AM
sweet, I can't find my Hanes Manual so I did a search and didn't find anything. But the dealer ship I took it to to tell me EXACTLY what was wrong with the car wanted to charge me almost $1400 for the Pump, New Opti, Coolant, and a Belt. Explative Deleted, Explative Deleted, Explative Deleted.
Old Apr 18, 2008 | 11:18 AM
When you go to re-install the pump, put that bolt in the hole in the water pump before you set the pump on the block. That way the pulley won't block access to putting it in.
Old Apr 18, 2008 | 11:20 AM
stereomandan's Avatar
I can't remember, but if there are holes in the pulley, you can access the PS bolts through them.
Dan
Old Apr 18, 2008 | 11:24 AM
I just got that bolt out. Are there 5 or 6 bolts on the WP? How do I not Fry my opti-spark when I remove the pump?
Old Apr 18, 2008 | 11:46 AM
6 bolts on the water pump. You drain the coolant to keep it off the opti.
Old Apr 18, 2008 | 11:57 AM
ss.slp.ls1's Avatar
First of all, how old is the opti? If it's original, I would strongly recommend swapping in a new opti while the pump is off.
Old Apr 18, 2008 | 12:50 PM
Yea, its a 96 with less than 90k miles, I just dont have the money right now to do the MSD billet opti like i would like to. Had I had this problem 2 weeks ago, I wouldn't have ordered the new valvetrain and been able to do the billet. The dealership this morning wanted to charge me 700 for a DELCO REPLACEMENT. I was like pphhhhhhssssssffff.
Old Apr 18, 2008 | 01:04 PM
ss.slp.ls1's Avatar
Here's a Delphi for $230:
http://cgi.ebay.com/ebaymotors/95-96...spagenameZWDVW
Old Apr 18, 2008 | 02:37 PM
You don't NEED to change the opti. If it's running fine, just wait 'till it fails. People have way more miles on their opti's without issues.
Dan
Old Apr 18, 2008 | 02:44 PM
ss.slp.ls1's Avatar
Dan
True, it was just a suggestion.
I've seen some last 150k+ and some less than 100k.
HectorM52
Jul 30, 2017 11:46 AM
Sandersen511
Jan 13, 2015 03:49 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
