Remove and install new Water pump
Old Jan 28, 2004 | 08:37 AM
  #16
Originally posted by Spllouder
ok a hex flats whats that ? after i unplug the one wire which i dint theres how do i get the knock senor out ?
Hex flats, you know, the place where you put a wrench? To get the connector off, you squeeze it and pull straight out. Then put your wrench or socket on it and unscrew it. 22mm is actually the size, but 7/8 is very close if you don't have a 22mm.
Old Jan 28, 2004 | 02:58 PM
  #17
Spllouder's Avatar
Thanks shoebox great pic, lol hexflat i was tried last night thanks iam still waiting for my pump since 630 Am its been out on delivery. its now 3:57 and still not here . Should be here soon .
Old Jan 28, 2004 | 04:37 PM
  #18
Spllouder's Avatar
Ok iam trying to remove the WP and i got the 4 bolts ot but the other 2 are tricky the one next to the air pump how do i get it off and the other on on left do i need to drop the belt to get to it ?
I got the 2 lower and 2 upper ones off i just need help with the two side ones thanks.
*Update * i got other two bolts off. right i had to drop air pump and bracket and left one was tricky dint drop belt just got it from underneath lucky it wasnt that tight .
still waiting for WP now its been out for delivery for almost 12 hours now its 7:18
have to do it tommrow
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
