Remote Quit now horn beeps
Old Dec 13, 2003 | 01:57 PM
bigjoebull's Avatar
My factory remote quit and now when I unlock my doors with my key the horn starts to beep within 30 to 45 seconds. When I put the key in the ignition and turn it, it stops. Is there a way to stop that (the horn)???
Also I get out and lock it when I shut the door the park lights blink.
Old Dec 13, 2003 | 07:12 PM
VegasZ's Avatar
If the alarm system is activated and you open the door with the key, you have about 20 seconds to turn on the ignition or else the alarm will sound. The only way around this is to deactivate the alarm and you need a remote for that.
Old Dec 13, 2003 | 07:45 PM
badazzcamaro97's Avatar
You need to put a new battery in the remote. The lights are flashing to show you that the alarm system is armed.
Old Dec 14, 2003 | 10:23 AM
bigjoebull's Avatar
I tried a new bat. but still nothing. Is there a way to unplug something?
Old Dec 14, 2003 | 05:37 PM
There is something you can unplug, but I cant remember where it is because I need to disable mine. I need to find to out from the guy who is trying to help me troubleshoot my problem with antitheft.
Old Dec 14, 2003 | 05:58 PM
VegasZ's Avatar
Most false alarms are caused by the shock sensor. It is taped to the inside fender well right above the spare tire. There is a sensitivity adjustment right on it and you can also unplug it right there. Unplugging it just dissables the shock sensor, not the other alarm functions.
Old Dec 17, 2003 | 02:31 PM
bigjoebull's Avatar
badazzcamaro97 if you find out any thing LMK.
Old Dec 17, 2003 | 08:19 PM
CamaroSS30thAnn's Avatar
yeha the same thing happend to my alarm.......replacd the battery in the remote but it still didnt work........anybody have any info on what it could be and how to fix it
Old Dec 29, 2003 | 04:41 PM
I have just been told that the relay for the anti theft could be bad. It can be unplugged to disarm the system. It is located on the passenger side airbag frame. You have to remove the dash to gain access, but I really hadnt had the time to do it.
Old Dec 29, 2003 | 06:54 PM
i ordered a new remote offline on ebay reprogrammed the code it works fine now
Aaront810
Aug 29, 2020 09:34 PM
KYWes
Sep 26, 2015 08:49 AM
greenzee28
Sep 25, 2015 04:29 PM
DelSoto
Sep 19, 2015 05:31 AM
cmsmith
Sep 14, 2015 09:09 PM
