reluctor ring
Old Jan 17, 2009 | 08:35 PM
01pewterz's Avatar
reluctor ring
What does it do? How important is it? And what if you forgot to install it?
Oh and shoebox if you read this, thanks for all the help from your cam swap pages, but you might add to install the reluctor ring after the timing chain for ******** like me.
Old Jan 17, 2009 | 09:07 PM
Stl94LT1's Avatar
It's for the crank position sensor, you car will throw a code without it. But, the code can be programmed out.
Old Jan 17, 2009 | 09:11 PM
01pewterz's Avatar
what if the crank position sensor isn't hooked up? Cause mines not. Its in my 84' Silverado.
Old Jan 17, 2009 | 09:15 PM
Stl94LT1's Avatar
I have seen where people eliminate the reluctor ring to run another timing set. But, not sure what it will do with the stock setup.
Old Jan 17, 2009 | 09:17 PM
01pewterz's Avatar
As long as there's not a problem with the balancer's hub going in too far and throwing off your serp belt alignment, you should be allright. I've seen where many eliminate the reluctor ring when running a different timing chain set.
ok, I was afraid that maybe it had something to do with keeping the crank sprocket on. I'll just ditch it then, too much of a hassle to pull the crap off to put it on.
Old Jan 17, 2009 | 10:33 PM
ak95ta's Avatar
If you still have the short hub, the sprocket could walk. I belive the hub holds it in place, and without the reluctor in there, you now have a gap.
Old Jan 17, 2009 | 10:39 PM
01pewterz's Avatar
crap thats not what i wanted to hear I guess I'll have to take it back apart and put it on. Thanks for the info
Old Jan 17, 2009 | 10:42 PM
Nothing in your sig indicates what year LT1 you are working on. The reason my guide does not mention it, is because the guide was made from my 1995 that does not have one. My pages say that the guides are 1995 specific, unless noted. Perhaps I will put in a blurb for those with later year LT1s.
Old Jan 17, 2009 | 10:45 PM
01pewterz's Avatar
cool that sounds good, my LT1 is supposed to be from a 96' Corvette. Do you think I need to pull the opti, hub, and timing cover back off and put the reluctor on?
Old Jan 17, 2009 | 11:03 PM
If the hub does not get all the way on like ak95ta said, you could have an issue. Also your accessory belt spacing could be impacted if there is any kind of variance. I'd probably put it on to be on the safe side. Or...if you do not really need the CPS, remove the hub and put a shim of the same thickness as the reluctor behind it. You should be able to do this without removing the cover.
Old Jan 18, 2009 | 01:39 AM
sbs's Avatar
sbs
Can't he just use an OBD1 hub?
Old Jan 18, 2009 | 06:49 AM
He could, if he had one and wanted to ditch the CPS. Either way, they hub he has now has to come off. He did not indicate he had another hub laying around.
Old Jan 18, 2009 | 08:58 AM
01pewterz's Avatar
I don't have another hub, so yes it has to come back off along with the opti, good thing I haven't put the wp or anything else on yet. Will I have to get another timing gasket now since I have to take the cover back off?
Old Jan 18, 2009 | 12:05 PM
If you do the spacer only, you won't have to remove anything but the hub. If you want to put the reluctor on, then the timing cover will have to come off after you lower the front of the pan and you will likely have to replace the timing cover gasket (depends on if it tears up during disassembly).
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
mmf_1013
Sep 12, 2015 08:56 PM
blaze309
Sep 8, 2015 05:27 PM
realistyc
Jul 28, 2015 07:32 PM
