relocated torque arms + x pipe duals....
Old Jun 2, 2005 | 09:15 PM
simple's Avatar
this is probably a dead horse
i searched and the majority of threads i have come across are OLD, like 2003 old
so i'm wondering if any one has gotten a tunnel mount torque arm too clear duals with an x-pipe yet
i prefer something along the lines of duals that are dumped before the axle, meaning the x-pipe is going too be right around the area where the tunnel brace mounts
right now i have a Global West traclink and it clears my Summit 3" universal x-pipe kit and full size Flowtech Afterburner mufflers with out any issue at all (kickass torque arm BTW!!)
but i might be switching too a Moser 9" (currently Moser 12bolt) and the traclink will not fit on a 9" rearend. i know this because the guy i bought it from tried too make it work and couldnt. (part of the 9" 3rd member interferes with the tq arm mount, (Global West Traclink specific issue with Ford 9's)
so if i do swap, i will need a new torque arm and too me a trans mounted torque arm is out of the question and stock is too because my stocker came out looking like a pretzel...quite literally
my other option is too use a tq arm like some of the stock eliminator guys use but it is very very loud on turns from what i have been told straight out of the horses mouth...great for track straight line use but not too great for a driver
has there been anyone brave enuf too make this work yet?
Old Jun 2, 2005 | 09:29 PM
1racerdude's Avatar
Re: relocated torque arms + x pipe duals....
Get a Spone and be done with it.It will fit either rear. The exhaust question is ya can't run anything over the L front of the TA mount. We USE 2-3 1/2" Y pipe into a 4" over the right side of the mount and 4" single out the rear in factory location.Ya could make duels with flatend tubing with a cross balance between the tranny pan and rear mount bracket in front of the TA mount, but any bends are $80.00 each 90* or 45* or 30* very pricey.
Old Jun 2, 2005 | 09:51 PM
simple's Avatar
switching exhausts is out of the question. i just put this on there and then the 9" deal came along
i'll probably end up going with the modified stock torque arm.
RUENUF
Mar 13, 2016 03:39 PM
Jason Short
Jan 19, 2015 06:34 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
